pacamper's avatar
pacamper
shore power connection led light flashing ??
Hey all,
I have a 2014 coachmen apex 288BHS, with a twist lock 30 amp power cord(Furrion 30A Square Inlet White F30INSPS), i just noticed that when plugged in at home, the blue led light on the tt power outlet lid flashes, is something going wrong with the light, or is this trying to tell me something about the power im connected too, it didnt do this in the past, i just have it plugged in, not using anything in the camper, except a light or two at times.
Thanks for any info
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There are no support documents related to this product and all the lit on it says is "In a blackout situation this super bright LED will tell you if its inside the RV or outside it"
    Question: When you plug into 30 amps at an RV park does it blink or glow steady..
    Question2/suggestion: Have you plugged in a Kill-A-Watt meter inside, pressed the Volts button and logged the reading, and what is it.
    If I were designing I'd use steady for good power, Flashing for bad power and off for no power but.. I did not design it, and that kind of thing costs a few cents more.
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 27, 2025
