RJsfishin
Dec 22, 2016Explorer
Quote:
There is some really TERRIBLE advice on this thread.
First, your RV has a 12 volt CHARGER. It is NOT meant to run ANYTHING. It is meant to charge your batteries. Your batteries run the 12 volt stuff. If you try to run your 12 volt stuff off your charger without batteries bad things can happen to the 12 volt stuff AND to the charger.
Really now ?
Shows to go you how much you don't know !!
Any converter that is standard in any RV, is a power suppy, whether you want to believe it or not. It is not a battery charger, but it does charge the battery.
Really now ?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
