Sam_Spade
Dec 23, 2016Explorer
06Fargo wrote:
I'm thinking I like batteries connected when running furnace motor loads...but maybe disconnect in warm weather when 12v loads are light :h
The fact that you have a "charge wizzard" means that you are just wasting time messing with it.
And every time you disconnect/reconnect something there is always a chance that you will drop a wrench and screw something up.
And for whomever it was that is trying to explain the difference between a battery charger and a power supply......there really isn't any difference when using those broad generic terms.
Any power supply can be used as a battery charger......and any battery charger can be used as a power supply......in some circumstances.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
