MrWizard
Dec 23, 2016Moderator
You should know the Mfg installed disconnect switch
Does not disconnect the batteries from the converter
It disconnects the dc fuse panel from the batteries
Some devices such as CO detector or LP detector are usually Not disconnected
By this switch
Using this switch when on hookups will turn off your lights and fridge
Not disconnect the battery from converter
By this switch
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
