time2roll
Dec 30, 2016Nomad
Cinder296 wrote:Most are fairly basic. 120vac in, 13.5vdc out. Need to put the voltmeter right on the output wires. Then verify power in is correct.
I have a 1998 American Eagle motor home. My batteries won't charge while plugged in off shore power. So not sure if inverter or converter- all in one unit. How can I test it to see which one is bad?
Would also help to know what the device is. OK to remove and bench test.
(you might get more answers by starting a new thread)
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
