time2roll
Dec 31, 2016Nomad
You need to fix-repair-replace the inverter charger.
Or if the inverter is still working you could just get a converter to charge the battery and supply 12v power.
If this seems like a bit much you are best to just haul it in for repair.
Again if the batteries are sitting at 10.6 volts they need a charge asap. Get a 10+ amp portable charger if needed to get them charged up. When charged they should sit at 12.65 volts.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
