- If the cell caps come off with a twist and pull of your fingers then you should lift the caps and check the water level.
Use distilled only. Fully charge first. Fill to 1/4" to 1/8" below the split ring that extends down into the cell. Just touching is absolute max.
If you are using a screwdriver or other tool to open the battery it is sealed. Leave it alone.
Picture of the top would help or at least a better description of the brand and model.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
