RJsfishin
Jun 09, 2013Explorer
One 100 watt solar panel is about the same as running a small 10 amp battery charger, but only when the sun is shining, and only if the panel is always pointing at the sun.
A single panel on the roof will be inefficient, because it will seldom be facing directly into the sun, therefore it will be like even a smaller than a 10 amp battery charger.
IMO, if you are going w/ just 1 panel, and you have a place to store/haul it, I would use it as a portable panel, then you can move it a couple 3 times a day, making it much more efficient.
Fixed panels on the roof are great, providing you have more of them.
Would I dare say that 1 portable panel, could put out nearly the same as 2 fixed panels on the roof, in a days time ?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
