wa8yxm
Sep 07, 2017Explorer III
The answer is likely either butr I"d go with the parallel 2000 watt.
Logic: you already have one so that is likely the cheaper upgrade
The 2,000 is lighter than the 3,000 so you wont' strain as much
You can, on occasions when you need not the A/C. run one and save gas
Two 2,000 watt Hondas provide a FULL 30 AMPS. the 3,000 does not.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
