- BurbManExplorer II
Cummins12V98 wrote:
IMHO that SH!T is just that! It doesn't stop creeping out.
There's a reason that every RV manufacturer uses it on every rig made, all the way from pop-ups to 6-figure busses. Your "high-quality sealant" is always used in addition to, not in place of, the butyl putty tape. - hedgehopperExplorerCummins12V98 wrote , "Use some quality sealant NOT silicone."
Such as? - Cummins12V98Explorer III
BurbMan wrote:
Anything attached to the outside of an RV gets a piece of this butyl putty tape under it. Use a piece of this tape under the flange of the door holder and then screw it into the camper. trim the excess tape that squeezes out as you tighten the screws. Caulk around the edges.
IMHO that SH!T is just that! It doesn't stop creeping out. Use some quality sealant NOT silicone. - BurbManExplorer IIAnything attached to the outside of an RV gets a piece of this butyl putty tape under it. Use a piece of this tape under the flange of the door holder and then screw it into the camper. trim the excess tape that squeezes out as you tighten the screws. Caulk around the edges.
- Tyler0215ExplorerIf you put a hole in the side or top of an RV you need to caulk first. Everytime!
Having RV issues? Connect with others who have been in your shoes.24,271 PostsLatest Activity: Jan 24, 2020
