Wandering_Storm's avatar
Jul 17, 2017
Shower caulk issue
I bought a Fleetwood Storm brand new in 2015. I noticed the shower seams were not caulked and applied a bead of silicone caulk around the base. The normal flexing has dictated that I do it again. I have since read that caulking this seam is not a good idea as it is left open for ventilation and drying behind the panels. Should I re caulk. Or clean it out and leave it alone? Any advice will be appreciated. Thanks John McD
  • Thank you for your help folks. The deal is sealed ( pun). No caulk in shower! McD
  • If the base has a flange that goes up behind the wall, I would not caulk the gap. I keep a spray bottle of bleach and bleach that crack once per week to keep the yuckies from growing.
  • I had a leak issue around my shower door where it met the walls and base, I used 3m marine caulk, it's about 20.00 a tube and takes seven days to cure, that was nine years ago and still no leaks.....make sure you clean it well before caulking......
  • NO CAULK
    If it is like mine (and most I believe) the bottom seam is an overlap that fits over the tub flange. Side seams (if any) I cannot be sure of until I see it or a picture.
    and quit using silicone
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
