Hi all, Our shower drain is draining extremely slow, we suspect hair clogging. What is safe to use to resolve this problem? We are in a 37' class A. Great water is not full. Thanks!
If above doesn't work, there should be an access cover on side of the shower pan (or tub) that provides access to the P-trap. If the P-trap can't be undone, you could possibly cut the 1 1/2" pipe and add a removable coupling - *if* you can reach into the tight space.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
