BNo do not plug the hole
That connection is a dual function item it is also a VACUUM BREAKER
now there is supposed to be a flat rubber circule in there. The way it is designed is is both a check valve and a vacuum breaker.. IF it is missing or if its dirty you get what you got. I suspect there should be something over the top of it either a plastic or metal Well do you know what the Bar-Sinister is (the circle with teh slash that means NO to whatever its slapped on IE the NO PARKING or NO SMOKING.. Well a piece that is like the bar sinsiter may go atop it. If you tossed or lost that piece or the rubber "Coin" that's your leak.
Just so you know.
If you plug the hole. then add a 1/2 inch Vacuum breaker (most RV stores may have and bigger plumbing places can get) just to be safe
