old_guy's avatar
old_guy
shower leak
after taking a shower in our rv shower we noticed a leak coming from one corner and the water running across the floor. two days ago I applied some silicon to the up right and across the lower flange and the floor pan. went out to give it a test and the leak is still there. tomorrow I will put another bead between the glass and the up right and across the bottom. wish me luck. if all fails I will paint the shower with silicon
  • Mine has a leak at one corner. It looks like the floor pan and walls are individual pieces and there is a space where they meet. Where that space meets the door frame, I think there is no sealer behind the frame member. I am hoping I can put some sealer in there without removing the door frame.
    Come to think of it, it probably would leak the same way at the other corner if the level leaned that way.
  • We recently had, and others also on this Forum, a leak when the floor drain separated from the piping.
    Also, can you check behind the wall for a possible leak in the supply piping to the faucets?
  • Quit showering is always an option.
    I have noticed when ever I do that, I usually get pushed to the front of any checkout line.
    Not a solution mind you, just a viable option.
Having RV issues? Connect with others who have been in your shoes.24,353 PostsLatest Activity: Jan 23, 2026
