UtahSunExplorerApr 11, 2018Shower valve flowHas anyone drilled the 1/8 hole bigger in there shower control where the hose screws on? Seems like you might get more volume with it opened to 3/32 or 1/4 inch. Just wondering.
Old-BiscuitExplorer IIIApr 11, 2018YES.......That is a 'flow restrictor' Some can be pried out/removed to increase flowIf not removable then 1/4" drill bit to enlarge hole for increased flowPump or city water supply can keep up with increased demandCommon way to get good shower flowFaucet aerators have restrictor plates also..they can be removed
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 29, 2026
Related ContentShower valves upgrade PICTORIALQuick connect exterior shower hose doesn't connect.No flow from hot water tank Nautilus P1 systemDry Camping Shower Valve ReplacementOxygenics Fury RV Handheld Shower head --COLD drip
