I have a coachman and just bought it used. I noticed that the shower walls are not flush with the walls. They have a bowed effect around all 3 walls. Will pop rivets, and sealant fix the problem? ...
Shower walls/surrounds have a lip around sides and top that is used to secure to wall studs and then trim goes over the area.
NO screws, nails, pop rivets or any other type of fastener goes thru the 'wall' area of shower/surrounds as that would create holes and water intrusion.
It would help if you could post up some pictures.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
