I have a coachman and just bought it used. I noticed that the shower walls are not flush with the walls. They have a bowed effect around all 3 walls. Will pop rivets, and sealant fix the problem? ...
How difficult would it be to remove the walls for inspection ? I would want to know what is going on behind the wall and what has possibly failed in the original installation. I think it would be preferred to NOT have screws , rivets or whatever puncturing the wall surface as you are just adding potential leak paths. Think about it the OEM didn't use them why should you ? But it's your camper so do what you feel comfortable with and within your skillset. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
