I have a coachman and just bought it used. I noticed that the shower walls are not flush with the walls. They have a bowed effect around all 3 walls. Will pop rivets, and sealant fix the problem? ...
Is it falling apart or is it just cosmetic to you? Mine is loose to the walls and has been since I bought it new. It is fastened at the top and sits in the base and does not leak. If you need to worry about it they do make a push pin but there is really no wall behind the fiberglass and very few studs. I for one would do nothing. Make a hole and rivet it ? too what? then the jiggeling that comes with travel will expand the hole and you will get water leak. Leave it alone.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
