I have a coachman and just bought it used. I noticed that the shower walls are not flush with the walls. They have a bowed effect around all 3 walls. Will pop rivets, and sealant fix the problem? ...
Maybe replacing the shower would be an option. Sometimes they put the cheapest thing they can find into them, that meets specs. It is probably a standard spec as to measurements. Not sure how well fastened in it. A heavier made unit perhaps with different fixtures, door etc If you're going to keep the RV for a long time it might be considered.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
