Think I may not have gotten all the water out of the system over the winter. Everything pressurizes just fine on city water, no leaks, yay. Turned on the water pump, and the flow is low, and never p...
Sounds like one of the winterization valves may be allowing the pump to suck air in the line. If you have a single lever Anderson valve you may start there. If you have the traditional open ended hose at the pump for putting in the antifreeze, you might check that the valve to the fresh tank is fully open, and the valve to the suction hose is completely closed if you haven't already done so.
