Think I may not have gotten all the water out of the system over the winter. Everything pressurizes just fine on city water, no leaks, yay. Turned on the water pump, and the flow is low, and never p...
Could be fill valve still open allowing water to round robin to tank Could be winterizing valve allowing air to get sucked in on suction side of pump Could be cracked suction strainer...pump casing Could be pump itself
Shurflo 4008 pump has an internal bypass valve. Bypass starts opening at 40# and is fully open at 65# But if stuck open pump can't build pressure or pump water to system
