RideSlowExplorerApr 05, 2017Shurflo 4008Think I may not have gotten all the water out of the system over the winter. Everything pressurizes just fine on city water, no leaks, yay. Turned on the water pump, and the flow is low, and never p...Show More
wa8yxmExplorer IIIApr 06, 2017Pump is self priming however on the initial use after winterizing it can take up to 5 minutes to pressurize the system. Three issues that can cause issues...1: If you opened the inlet strainer housing and drained it and did not get it properly closed 9Rare but it can happen)2: Closed tank outlet valve or open drain on some systems (Again not all that likely)3: (Suspect #1) Open low point drain valve
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
Related ContentShurflo 4008-101-A65Shurflo Revolution 4008 severe hammeringShurflo 4008 or 4048?Shurflo 4008 RV Revolution by pass pumpShurflo 4008 repair kit
