Think I may not have gotten all the water out of the system over the winter. Everything pressurizes just fine on city water, no leaks, yay. Turned on the water pump, and the flow is low, and never p...
I will add. the type of plumbing used in RVs (PEX) survives freezing rather well even with water in the lines.. It is the fittings, Elbows, Adapters to faucets and valves and such, those are what break if it freezes.. Just so you know
And those were likely very dry based on what you said you did.
