Think I may not have gotten all the water out of the system over the winter. Everything pressurizes just fine on city water, no leaks, yay. Turned on the water pump, and the flow is low, and never p...
OP - Is the line that supplies your pump, connected to a tee at the bottom of the tank, with the other side of the tee going to the tank drain valve? Those drains, or the hose connection to them, can let the pump pull air through just the smallest of leaks, and the pump won't pressurize your water system.
