Think I may not have gotten all the water out of the system over the winter. Everything pressurizes just fine on city water, no leaks, yay. Turned on the water pump, and the flow is low, and never p...
Those pumps are notorious for not shutting off, if the bypass adjustments are not adjusted correctly. If it slows down.....like it wants to shut off but doesn't, then it needs adjustment
