bigfootford
Oct 30, 2013Nomad III
fj12ryder wrote:
CCW? CW? The chirp sounds like the noise mine made, it almost sounded like there was something caught in the fan and was hitting the blades. That is what I checked for first.
Yep that's it.. My fan turns either direction. CCW or CW.
Chirp/ squeak...Definitely bearings... Needle/roller bearings are for non thrust in and out... A fan puts either a pull or push on the stator.. So a method of keeping the stator from moving in and out. Needle/roller bearings can not handle in and out thrust. The Race and rollers will rub/squeak and wear.
I need to order bearings for my original motor to fix. Gave up on Shurflo!
Jim
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
