azbohunter
May 12, 2014Explorer
dbbls wrote:
There is a check valve in the pump. Sounds like your is bad. You can rebuild the pump, get a new one, or install a check valve between the pump and fresh water tank.
I was aware there was a check valve and had considered that but I was thinking that kept water from flowing back through the pump when hooked up to city water.
Can you explain how this works, not doubting you, anxious to understand it better!
Thanks,
Dick
