AH64ID
Mar 23, 2014Explorer
bowler1 wrote:
Hi,
This is a follow up to my post from yesterday about starting AC with a generator--thanks so much for all the help!
Seems that the next thing I need to try is to ensure my converter is shut off prior to trying to start the AC.
Can anyone tell me how to do that? I assume there will be a breaker in the circuit box that should allow me to do that. I don't have my RV here at home so I will have to check it out next time I head out to where it is stored.
thanks
Matt
It will be tied to one of the breakers, on both of the TT's I have owned it has been one of the general breakers.
Start the generator and turn on a few lights, then start flipping breakers. When the lights dim you found the breaker you need to turn off.
If it's not a separate breaker it's easy to make it separate, or add a 15A switch inline for easier shutoff.
Artum Snowbird wrote:
Yes, your converter is just another load and will be labelled on the breaker box. If you look at it, many converters are capable of putting out 45 amps at 12 volts. That works out to 540 watts if it's working hard trying to charge low batteries. Not often it would be running that busily, but it is a sizable sum.
There is quite a bit of power loss when converting, so the draw will be larger than 540 watts, and the voltage is higher than 12 so the watts are also higher. Output is probably closer to 610-650 depending on charge voltage.
My 55A converter output is up to 800w, but draws up to 950w.
The 45A version of my converter draws up to 750w, other 45A converters will be similar.
RoyB wrote:
Cutting off your converter will also kill your 12VDC inside your trailer so those items will have to run from your charged up connected battery. You will need some 12VDC power to keep a few things running inside the trailer... Ceiling lights is one item you will probably want to have working which only runs from 12VDC coming from the Converter or the Battery.
One other thing I would do if the batteries needed a charge and I needed A/C was let the batteries charge for a 20-30 minutes and then start the A/C this really lowered the load from the converter.
RoyB wrote:
If my roof air conditioner ever needs replaced I will get a 9,500 BTU size replacement roof mounted unit. Those will work just fine with the 2KW Honda EU2000i generator as well. We don't use the A/C all that much in our OFF-ROAD POPUP setup anyway as most of the time we are sitting in well shaded woods camp site anyway. FANS work great in there for us...
Roy Ken
I had a 9K BTU A/C in my 18CK and I didn't have to turn the converter off to start the A/C until I went from 1 12V G24 to a pair of 6V, even if the 6V where at a 80% SOC (normal for summer camping when the A/C is used) the converter was drawing too much to run both.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
