Rick_Jay
Aug 12, 2022Explorer II
SJ-Chris,
I applaud you for your solution to prevent the slider bolt from extending all the way. I could tell from your pics that yours didn't break. However, it WILL break. And this guy named Murphy will tell you that when it does, it will be at the worst possible time. :) You've already closed the door (probably several times) with the slider bolt over-extended. That put lateral stress on that part, and might have already weakened it. That's the problem, when it breaks, there IS no warning. The door does NOT open and you're trapped...either inside or outside.
The first time this happened to our rig, I was surprised how many others had the EXACT same problem. And like I said, we pretty much babied the closing of the door...I detest door slammers! LOL Anyway, I believe, there were some folks who sent documentation to the NHTSA to see if Tri-Mark could be forced to fix this as this could conceivable be a life-threatening failure if the lock broke and there was a fire inside the RV. Perhaps a "perfect storm" of problems, but not outside the realm of possibility. We have a driver's door on our Class A, but if the fire is at the front of the rig, that door would be useless. If the main entrance door didn't open, then wifey and I have to try to squeeze our "not so skinny" butts out the emergency window in the bedroom with the requisite "fall" to the ground. LOL
Ok, just my line of thinking, but what I paid for that upgraded steel bolt and the peace of mind it provides, I felt it is well worth it. I didn't want to take any chances, and when the kit mentioned above became available, I quickly ordered it and installed it.
I'd recommend that you order it. The frustration you save will be your own! ;)
Safe travels,
~Rick
Safe travels,
~Rick
