haste_maker's avatar
haste_maker
Explorer II
Jan 04, 2021
Side Out Trays
Thinking about having basement side out trays installed in my 2007 Allergo 32 BA, would like to hear from someone that has done this & what did you use for the trays.
  • Both of mine are dual acting and extend 5' out on either side. One that I bought in 2005 is assembled with a plywood base and hence can be set up for any width. There is also no metal lip on the ends which means I can extend out from the base as needed.
    The second one came with the current rig and is all welded steel including a steel lip on the ends.
    There is space under each storage slide for poles, hoses, etc.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
