buzzard616's avatar
buzzard616
Siding replacement
Siding on signature TT has seen a couple of hailstorms over the years and is starting to look like a square golf ball.
If I replace it I'm not using the same tin-foil siding it came with.
Is there something else, even vinyl siding that will work and be able to stand small hail?
  • Not really- Filon is available, but that is a different construction technique- laminated walls. I'm not sure how much you need to replace, but that siding is not cheap.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
