path1's avatar
path1
Simple fix turning into nightmare/fishing a wire ideas
You ever have something really simple. Then messed up and create more work?
My right side tail light has been acting up. When trouble shooting it I find out a little glob of solder is worn out and not making contact with the bulb. I take it out tail light and unplugged the wiring harness. I’m going to see if I can solder a little bit on for better contact or maybe I’ll get a new one. Should be no big deal. I get a plastic bag and duck tape to cover up the hole because I don’t want any water in. Slapping on the duck tape, the tail light wire from the inside sticks to the tape, I pull tape back just a little to free up the wire and wire sort of recoils back into the hole. I look and can’t see it. I do see some luan wood. I go on inside of RV to take a better look. The luan is the backing for my closet and underneath the closet there are 2 drawers. Which the drawer fames are attached to the luan. I pull out the 2 drawers and there’s the water heater behind the drawers.
So if I can’t fish out the wire somehow I’m going to have to remove water heater, closet doors, drawer slides and frame and the piece of luan just to grab hold of the wire to shove it back out of the hole.
Anybody got any good ideas for fishing out a wire that you can’t see or grab hold of from outside?
  • How about trying a vacuum cleaner. One with some good suction should pull it right out.
  • path1 wrote:
    You ever have something really simple mess up and create more work
    Oh yeah, and just how is it that we are related?
  • Take some bare steel wire and form it around a broomstick to make a spiral with the loops about 3/4" apart. Feed it down into the hole while twisting it. With luck the spiral will snag the taillight wire well enough to pull it out.
  • I would get something like this:
    http://www.amazon.com/X-Long-Flex-Cable-Pick-Up-4-Finger-Retriever/dp/B006ZEOXJY
    And a small mirror and flexible led light. Check harbor freight...they may have everything.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
