DarkSkySeeker's avatar
Jan 10, 2018
Simple Heater "Fix"
I woke up on a cold morning during my last camping trip. The heater in my trailer was not running as I expected. If you are like me, you know that feeling of dread that perhaps a complex problem was about to unfold.
I crouched down to open the fuse box and immediately noticed a red light was on. I assume this indicated a "fault" of some kind. The labels for the various in-line fuses showed me the red light was next to the heater fuse.
I reached out to see if it would be easy to pull the fuse to replace it and my finger bumped the fuse. There was a tiny spark, the red light went out, and the heater came on. I subsequently manipulated all the fuses by pressing them firmly into their sockets.
I guess the heater fuse just worked its way out a little. No big problem, It left me feeling very grateful for small miracles.
  • I use the auto changeover feature so I don't have that problem.
    Ia that a gadget I need? My changeover is manual.
  • DarkSkySeeker wrote:
    DutchmenSport wrote:
    Fortunate for me, in all the years of RV ownership, the only problem I've ever had with the RV furnace was a propane tank running out in the middle of the night and I'd have to get up and switch over to the other tank.
    My trips have been warm and short enough and my tank is large enough that I have never had that problem.
  • Chum lee wrote:
    Repair principle #1: "ALWAYS CHECK THE MOST SIMPLE THINGS FIRST"
    And Rule 1B is "don't always expect the worst"
  • Good advise!
  • Repair principle #1: "ALWAYS CHECK THE MOST SIMPLE THINGS FIRST"
    Good job!
    Chum lee
  • Old-Biscuit wrote:
    go thru your AC Main Panel and tighten up ALL wire terminal screws....Incoming side, grounds, neutrals and load side on the circuit breakers.
    Good tip, thanks. It makes no sense to invite/ignore loosened connections.
    Now that you have 'reseated' the fuses
    "Reseated" - a good word for it.
  • Now that you have 'reseated' the fuses for DC System go thru your AC Main Panel and tighten up ALL wire terminal screws....Incoming side, grounds, neutrals and load side on the circuit breakers.
    Everything has a tendency to loosen from all the shaking/vibration/bouncing going on during transit
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Jun 17, 2022
