Snowman9000
Sep 15, 2013Explorer
TomG2 wrote:
I guess I don't know how to ask a question. Will a 200 watt portable array that is aimed at the noonday sun in a place like South Texas be the equal of a XXX watt system laying flat on the roof? I am not asking for exact numbers (those seem to be nearly impossible to come by anyway). Forget about the difficulty in propping up the panels, I need the exercise and own a generator.
I'm going out on a limb and guessing you mean in mid-winter in south TX. So I went to a sun position calculator. I put in Vancouver BC for May 15, and Mission TX for Jan 15. Then I looked at the amps that BFL got for certain sun angles that I could use on the Mission chart.
I didn't go to the trouble of plotting it out and adding it up, but my educated guess is that 200 watts tilted and moved (tracking) 2 or 3 times during the day in Mission on Jan 15 would be about the same output as 500 watts or more, flat.
Examples: BFL's 0800 reading would be your 1030 and 1500 readings. At those readings, 200 watts of tilted panels would equal 570 watts flat.
Your 1200 noon reading would be BFL's 0900. At noon, your 200 watts of tilted would be equal to 400 flat. That's about as close an answer as you'll get, I think. If you want a different date, just say so. Mid winter is worst case for flat panels, and best case for tilted & tracked.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
