BFL13 wrote:
I did measure my results with the 130w panel (it is all proportional, so you can work it out for your 190w) in May at 49N when tracking was moving it three times a day.
Flat-56AH
Tilted aimed South all day-70AH
Tracking with fixed tilt-90AH
You can see that two of those 56s is 112--more than the 90. But that was in mid-May at 49N
You can't escape the details (the Devil is in the details!)
When the sun is higher you get less difference between tilted and flat. Longer daylight time gives more diff between tracking and not.
With the longer daylight you get more angle the sun goes around where it rises and sets more north of east and west up to 23 degrees more each side in June.
So in March and Sep it is 180 degrees and in June it is 226. Dec gets you only 134. The sun moves around at 15 degrees an hour. (Earth rotation) So June gets you 226/15 = 15hrs, Dec is 134/15 = 9 hrs and Mar or Sep is 180/15= 12 hrs
Tilting is affected by the sun's declination changing that 46 degrees back and forth every six months too. That's 7.7 degrees a month to change your tilt. (about 2 degrees a week)
When you move south for the winter, you get under a higher sun than up north but you still have the shorter days
In summer with more than 180 degrees of sun travel sunrise to sunset, you get the problem that your rig casts a shadow part of the time when the panel is placed on the ground to the south side. This is why I put my first tracker on the roof so it could see all around
Great info' I made another print copy of a BLF post. Keep 'em comin'
O$S
