Gerald55's avatar
Gerald55
Simple way to measure coach battery capacity
I'm looking for a reasonably simple way to measure the current capacity of the single coach battery in my newly purchased (used) RV.
I have a basic voltmeter which I don't think will be much help, but I do also have a kill-a-watt - so I figure maybe I just charge up the battery, then turn everything off except say the TV which I plug in through the kill-a-watt and measure it that way? Any downfalls to that approach?
  • I'm not sure how long it has been in there since I don't know the history. I guess I should say that it's likely between 3 and 8 years old.
  • Gerald55 wrote:
    Thanks for the suggestions! Yes I was definitely asking about testing the actual capacity of my battery, not the nominal capacity which is easy to look up.
    I've just bought a new rig with a battery that has probably been in there for ~8 years, and possibly abused, so I wanted to know how much extra capacity a replacement could give me.
    I wouldn't even spend time analyzing an 8 yr old battery.
  • Thanks for the suggestions! Yes I was definitely asking about testing the actual capacity of my battery, not the nominal capacity which is easy to look up.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Group 24 73 amp hours
    Gropu 27 95
    Group 29 105
    Group 31 130
    Two GC-2 in series 220 give or take 10
    4D 230
    8D is I think 220 but not sure
    Or is your battery not on this list.
    This applies to batteries about 1 week to 1 month old
    IF your battery is getting on in years and you suspect loss of capacity take it to a genuine battery store.. NOT an auto store but someplace that sells batteries and only batteries.. Many of them can test it for you.
  • Good, solid, home-brew testing. The only variable of course is battery voltage which means wattage through the light. But for comparative testing New/Now it is priceless.
  • red31 wrote:
    I've always got a chuckle out of this method, knowing the ever changing current of the inverter, light and clock is the issue!
    analog AC clocks are extremely useful for things like this and simply looking to see how long the power was out at home. Any idea where this one came from?
  • RoyB's avatar
    RoyB
    Explorer II
    When we are camping off the power grid I just watch my homemade three meter BATTERY MONITOR panel (Two 12VDC Meters and one 75 DCAMP meter). My meter panel looks similar to this drawing for my Battery Monitor Panel
    When the battery bank DC voltmeters drop down to the 12.0VDC level I can assume this is pretty close to being 50% charge state. This is not absolute but close enough for me. I will either start my battery charging routine or disconnecting the batteries from the system.
    In my case I have planned all of this out and I usually see the 12.0VDC 50% charge state at 8AM each morning when I would normally charge up my batteries to their 90% charge state using smart mode charging techniques...
    With my 255AH capacity battery bank we can run 22AMPS DC current from 6PM to 11PM including the parasitic drain and make it through the one day/night run off the batteries and just be at the 50% charge state at 8AM the next morning. We run all the 120VAC items we want to run from a PSW INVERTER and the 12VDC items direct connected to the battery system.
    Then recharge the batteries during breakfast the next morning starting at 8AM in a three hour generator run time when allowed which will make us good for the next day/night run off the batteries.
    This is how we do our camping off the power grid runs...
    Roy Ken
  • If you just want to know what the battery SHOULD provide, just look up the size and look at any rating, you'll be close.
    Your method of testing would work fine.
    I don't have a Kill-a-watt, but I have a Voltmeter and Ampmeter. I am in the process of testing my 2 GC's, using an inverter and a slow cooker to load at about 11 Amps. Checking and recording voltage and current draw every few hours, will give me a good approximation. They're 8 years old, and a few years ago they tested at 80%. We're getting ready for a couple of months on the road, and rather than trust to luck, figured I ought to test them.
    Doug
  • I've always got a chuckle out of this method, knowing the ever changing current of the inverter, light and clock is the issue!
  • Why not just look up the rating for your particular battery? :h Yes, there will be some small differences from brand to brand but within a given group size a battery's rated capacity will be similar to that of another brand in the same group size.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
