MrWizard
Jul 23, 2015Moderator
my experienced ? guess would be anywhere between 13.8 and 14.1
this is float range and can be held indefinitely
i have my Solar cranked up to put 14.1 at the batteries
and when i do my once a week BD vector top off i try to go to 14.8
i (4) 60ampHr agms and (4) 139ampHr agms
you are charging Unless you exceed the output of the chargers
at that point you are discharging, just doing it at a slower rate than if the chargers were not on, this will cycle.. charge - discharge as the loads change, but it is ONE or the Other
not both at the same time.. but we know what you mean
if shore power is available for days at a time, i suggest high end of float voltage
you can go higher if it is only for a few hours
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
