SoundGuy wrote:
brulaz wrote:
Knew I'd seen reference to this issue somewhere. It was in the Prog Ind EMS manual.
They say in an RV you should "never bond the neutral and ground together for any reason". Bonding in an RV "will create a ground fault condition and may result in electrical shock and or fire hazard"
Pretty explicit; the neutral and ground should remain isolated in an RV, unlike a house.
So separate from whether the Inverter can deal with it, Prog Ind EMS explicitly says no.
So exactly HOW is one supposed to meet this criteria when simply plugging the trailer's main service cable into the inverter output seems to automatically bond the neutral and ground together? :h
Could it be your Surge Guard doing this?
(Wish I was up at the trailer to do some testing ...)
