SoundGuy wrote:
Seems like you're currently between a "rock and a hard place" if your new EMS won't pass the inverter's floating neutral output but the manufacturer warns against bonding. :E
By putting the relay (transfer switch) between the EMS and distribution panel, the issue will be resolved to my satisfaction.
The result should be a non-bonded, floating, 120VAC RV, same as it is now, same as EMS likes it, and in agreement with at least some of the commentators here. :)
Once installed, I can smell the roses, or swat bugs, but I will not pursue the bonding/non-bonding arguments. I have little tolerance for head banging. :B
