path1
Jun 27, 2017Explorer
OP here...Thanks for replies
Think I finally found a reason, at least in my mind
After lots of looking around found this
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=71
"Additional considerations require that all four tires on the rear drive axle be equivalent. Ideally this means tires should be the same model and have identical remaining tread depths. Any discrepancies between the four tires will result in the taller tire(s) being forced to carry more than their fair share of the load.
Light truck tires that are intended to be used in dual applications have two "Max Load" ratings branded on the tire's sidewall. This is because the load capacity rating of a tire serving duty in a "single" application is greater than the exact same tire being used in a "dual" application. For example, a LT235/85R16 Load Range E tire is rated to carry 3,042 pounds when inflated to 80 psi and used in a single application, but only 2,778 pounds when used in a dual tire application at the same inflation pressure.
This reduction in rated load capacity results in slightly larger tires being specified for the application that can better withstand...
the additional stresses experienced when a single tire goes flat and the three properly inflated remaining tires are required to temporarily carry the load at reduced speeds to remove the vehicle from immediate danger. This load reduction is not a concern for vehicles originally equipped with dual rear tires because the vehicle manufacturer factored it in when they specified the tire size for the vehicle."
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
