- ValkyriebushExplorer IIUp date. Job completed by mobile tech at home. New moen faucet installed. 150.00 for faucet, 17.00 for new valve adaptors receipt provided. $65.00 to remove and install.
- ChrisatthebeachExplorer
nomad.297 wrote:
As a plumber, I run into this several times a week. If it is rusted like yours is, I don't even attempt to get the nut off from beneath. I use a Sawzall or hacksaw to cut the faucet off from above. Put your blade right where the valve body and base meet, at the gap, and saw right through it. The bottom of the faucet will drop right out of the bottom. It is always easier if you can pull the hose out first, but if you can't, it just takes a little longer because the blade jams on the hose flopping around inside the body. Trust me, this is easy.
Bruce
This is what I did, cut it, threw it away and bought a replacement at Wal-Mart and have not looked back. - nomad_297ExplorerAs a plumber, I run into this several times a week. If it is rusted like yours is, I don't even attempt to get the nut off from beneath. I use a Sawzall or hacksaw to cut the faucet off from above. Put your blade right where the valve body and base meet, at the gap, and saw right through it. The bottom of the faucet will drop right out of the bottom. It is always easier if you can pull the hose out first, but if you can't, it just takes a little longer because the blade jams on the hose flopping around inside the body. Trust me, this is easy.
Bruce - path1ExplorerCouldn't get mine until I got one of these.
http://www.amazon.com/Moen-118305-Installation-Tool/dp/B002PB1JJS
Maybe removing sink would be better, especially in tight quarters. - Houston_RemodelExplorerDon't be surprised when you exert enough force to break something.
Removing the sink is worthy of serious consideration. - Happy_ProspectoExplorerAs rusty as that connector guizzy is, you may have to remove the sink to get enough room to work on that faucet easily.
- Gene_GinnyExplorer
Old-Biscuit wrote:
Look at the shadow in the first picture and you see a profile that matches this picture from Old-Biscuit.
Under that rust the flex hose unscrews and then a nut unscrews from faucet threaded tube (which feeds flex hose)
Good find. - Dick_BExplorerI think there is a threaded rod sticking down from the faucet thru the moon shaped piece which needs to be unscrewed. It may take a deep socket and impact wrench.
- Old-BiscuitExplorer IIIUnder that rust the flex hose unscrews and then a nut unscrews from faucet threaded tube (which feeds flex hose)
- busyguyExplorerHi Chief
I think that is held on by a clip. Been a ling time since I ran into one of these. You may try to knock it sideways with a hammer or try turning it with a pipe wrench if you can get to it. There may also be a set screw somewhere on the collar. Doubt if you would ever get it out if there is one. You may also try cutting it off with a dremel tool.
Sorry I can't help more
Busyguy
Ret AF Msgt
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 18, 2025
