pianotuna
May 22, 2022Nomad III
High draw on LiFePo4 is limited by the battery management system. It depends on what the maker sets it at. Anyone know what is most common? 100 amps (1c)???
Seeing as my goal is a battery bank of at least 400 and possibly 700 amp-hours, the speed of charging of Li is not useful to me--as my fastest charger maxes out at 127 amps @ nominal 12 volts.
Efficiency also does not concern me as I want to float the batteries between trips. SiO2 float nicely. Li, not so much.
For me, the most important factor is full charging not required on each cycle. My understanding is that both Li and SiO2 are quite happy, if they are fully recharged once every 30 days.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
