BFL13
Nov 09, 2020Explorer II
I thought the comment from that boat guy on Li was useful. He said they work for full-timers but not for weekend warriors. I will try to cut and paste that here on Edit.
Even if I had unlimited funds, Li would not suit me. Too fussy with all that BMS and what not makes them sound too delicate, but I gather that may not be really how it is. Anyway, that's just me. YMMV.
I remember some years ago running the converter from the Honda, a Vector charger from an inverter strapped to the truck battery while idling, and solar all adding their amps just fine. You just need the various chargers to be at nearly the same voltage and all higher than the battery's voltage, and they add their amps.
"Fast charging" seems to have several meanings for folks. It does not mean way high amps as such. You have to know the acceptance rate curve along the SOC range. You can get the way high amps for the first ten minutes and then they might be the same after that, so all you did was save 10 minutes of gen time. It depends! Then as PT said, you still need a way to achieve those high amps wrt the battery bank size in AH. A big bank can mean your generator can only run so much of a charger in amps, and that's that, which miight only be a normal level of charging rate anyway, so even if the battery bank could take more, you don't have it. :) anyway, off to find that boat guy's quote---(link on back on page 6 of this thread (trawler one) page 2 of that at the bottom)
"The weak point of LFP at this time is the care and feeding needed: they want to be stored in a partial state of charge, and that is not so easily done. With LA batteries in intermittent use (like most boats) you just return to the marina, plug them in, a proper charger brings them to a float state while you walk away. LFP on the other hand, should be run down to 40 - 60% before leaving them. Then when you return next month you are starting the weekend with partially discharged batteries. Currently, that makes LFP a better fit for live aboard on the hook use where they have many advantages, vs. weekend use stored in a marina, or marina live aboard.
The carbon foam batteries seem to have nearly the same life kept in float or partial state of charge - that's why people are paying more for them. No one seems to know on SiO2."
EDIT--here is something on Li fast charging where it says you can over do it and wreck the battery from overheating. There is another one about why charging is slower than discharging C rate if I can find it again
https://energsoft.com/blog/f/c-rate-of-batteries-and-fast-charging
EDIT- " Normally high discharge rate batteries can be fast charged. However, since lithium ions are embedded in the negative electrode graphite during charging, the process of inserting lithium ions into the positive electrode during the discharge process is difficult, so the fast charge ratio is generally lower than the discharge rate"
https://www.grepow.com/page/high-discharge-battery.html?gclid=EAIaIQobChMIsNOZxqr27AIVLiCtBh3YoAphEAMYASAAEgJZWvD_BwE
Note--I find that last one might have a typo or something? Says discharging difficult, so charging is slower?
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
