BFL13 wrote:
3 tons wrote:
Ha, you’ve seem to omit the following from my above aforementioned quote as follows:
(Per) “Vendor Betta’s sage Advisory”...
Context matters!...So are we to assume your dismissal of adherence to Betta’s Advisory??
3 tons in RealVille
Not at all. They discuss how soon the batt will suffer and what that depends on and if you don't get to 100% often enough. The advice to get to 100% monthly is presumably a time chosen to be often enough so they are not ruined from that.
Don't you also have to get to 100% every so often with LFPs (although for a different reason), so you still have to keep an eye on things when on solar to some extent, and not be "passive" for too long?
"IF" the cells are unbalanced "maybe". LFP aren't required to have long drawn out charge/ equalization. No need to go down the NOVA again. ;)
