MNtundraRet
Nov 18, 2015Navigator
I have been using a Coleman CL-600 solar panel, 600ma, 15V, 9Watt, for about 5 years now. I have 2 panels: one for V10 starting-battery, and the other for the pair of 6V Trojan T105's.
MH is stored for 5 to 6 months with only the solar-panels. I check monthly and run engine, and generator (if temperature is around 20F or higher). Done to exercise both as needed. I always check batteries with volt-meter before starting engines. They are always found at full charge.
It should be noted that I have no currents drawing down batteries. If you have a radio with digital displays drawing current continuously you will need 5 or more watts.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
