Community Alumni
Nov 18, 2015I have the exact charger (5 watt) and have used it for 4 winters to date. The vehicle is a Ford with 2 batteries. The truck may sit for 7-10 days outside between use. Prior to using the charger the batteries would be low and the engine would start but turn over slower then it should. With the charger I connect it immediately after shutdown from a drive. I use the lighter plug and lay the panel on the dash. When I start the truck again the engine turns over and starts normally. The charger works for me. :C
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
