- bobsallyhExplorer IIThey now make plastic blades for the multiuse tool, just like plastic razor blades. Heat the sealant, then use multiuse tool at a slow speed and be patient. It works!
- path1Explorer
ksg5000 wrote:
I use an oscillating tool (rockwell sonicrafter) and a special rounded blade designed for removing caulk. Makes removal an easy job and rounded blade won't cut the rubber roof. Heating the caulk a bit may help.
Tell more, sounds interesting... what size you got. How much have you used?
OP, chime in when ever, not trying to take away. - ksg5000Explorer III use an oscillating tool (rockwell sonicrafter) and a special rounded blade designed for removing caulk. Makes removal an easy job and rounded blade won't cut the rubber roof. Heating the caulk a bit may help.
- ScottGNomad
donn0128 wrote:
Plastic scraper, heat gun and a lot of patience.
X2!
PIA but it works. - donn0128Explorer IIPlastic scraper, heat gun and a lot of patience.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
