chiefward's avatar
chiefward
slide adjustment
I need to adjust my 12 foot slide 3/4 inch to the left to center it in the opening. (One side in slightly dragging. ) I see how to loosen the slide from the slide frame but need suggestions on how to move it once it's loosened. Would I just give it big push?
  • If you do not have any leaks now from around the slide check for leaks after the adjustment. Sometimes the seals will not adjust to the new slide position on the seals,
    Don
  • Thanks mchero. Half way was my thoughts too. Going to try it tomorrow morning, it's 101 degrees on my carport right now.
  • 1/2 way sounds like a good idea.
    EVEY time I put my full slide out I'm waiting for the day itkeeps going out & then drops out to the ground!
    Thos full slides are amazing "when they work 100%"
    LOL
  • Thanks for the info. (I never thought to read the instruction manual.) Do you think the slide should be extended all the way out or maybe halfway to balance the slide room on the trailer edge?
  • Yes, I was about to post, that we get more information on the slide.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
