I always had this issue so I always thought it was how the slide sounds. 1) The slide seals and there is no water leak 2) When I half open the slide and measure from wall to end. the difference i...
If yours is a Lippert electric slideout, you just need to google it, adding adjustment to the search. It should adjust side to side, if that's what you are needing.
Jerry
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
