Hello, Posting this for a friend that just bought a '98 TS EXPRESS 5er. Has three slides but one will not slide out. I've not seen the 5er as we live 2100 miles apart. I've never had a slide out but ...
Yes there should be a manual crank to operate the slides. Each one should be independent.
You need to ask if the slides mechanisms are electrical or electric/hydraulic. There can be additional considerations with electric/hydraulic.
Just off the cuff guess there are likely fuses, broken wires or worn out switches causing the problem but this can take time to troubleshoot. And may require someone with some knowledge of how they work.
OT: How is beautiful Socal? Raised in SFV.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
